goez Posted November 11, 2005 Report Posted November 11, 2005 hi all, how can i fix the Mx component when i install GX developer v7 in Windows XP? the MX component don´t works at all...I need to uninstall both of them, and reinstall MX component to fix that......is another way to fix it? sorry for my english hola a todos como puedo arreglar el MX component cuando installo el GX developer en Windows XP? MX component no trabaja.......necesito desinstalar ambos programas, y reinstalar MX component para arregarlo.....hay otra manera de arreglarlo? Quote
panic mode Posted November 11, 2005 Report Posted November 11, 2005 well you could try reinstalling MX Components alone... I never had such problem. Quote
Guest Guest Posted November 14, 2005 Report Posted November 14, 2005 And i suggest to upgrade Gx developer to version 8. I'm not sure but version 7 is not compatible with Xp bye Quote
panic mode Posted November 14, 2005 Report Posted November 14, 2005 i use it with XP. i'm not sure what should make it compatible or not. if it can work in XP like in any other OS, that's compatible enough to me. version 8 has some nice features but not enough to make me switch over. Quote
