anyaddress Posted November 15, 2005 Report Posted November 15, 2005 Hi all plz I need ur help, I have a modicon micro plc and the error lamp is flashing (red colour), this happened before from 1year I just changed the backup battery ,reprograme the plc with the application and every thing is fine and machine back to work normally, now I replace the battery with a new one (knowing that battery low level indicator doesn't light),the error led is still flashing but the machine just working fine except for error flashing, I reprogram the plc with the original application and run it nothing happen the error still flashing but the machine is working, using my pl7 micro software I go to diagnostic mode and it indicates that the last fault is caused by battery (I replaced battery,reprogramme plc but error is still flashing ) any suggestion to know why error lamp still flashing knowing that I have modicon plccmicro (pl7 micro) with a memory card thank you Quote
Crossbow Posted November 16, 2005 Report Posted November 16, 2005 Did you power cycle the PLC or stop it and start it after the battery was replaced? That error latches on. Quote
Guest Guest Posted November 16, 2005 Report Posted November 16, 2005 i take the old battery out,put a new battery ,reprograme my plc (i stop the plc and then run it) nothing happen error lamp still flashing knowing that the nachine working fine also i compare the application inside plc with the original application and its was IDENTICAL,any sujjestion plz Quote
Crossbow Posted November 20, 2005 Report Posted November 20, 2005 I'd have to dig up the CD with the manual, but there is a list of reasons that would apply. I'll find the manuals on the TSX Micro and post them later today. Quote
