where did you look? download section of Mitsubishi website www.meau.com? you should be able to find hardware manual JY992D66301-J 3.64MB http://www.meau.com/functions/dms/getfile....000000207502000 you might want to download programming manuals too http://www.meau.com/functions/dms/getfile....000000204800000 http://www.meau.com/functions/dms/getfile....000000211602000 since it's MR unit, it will have relay outputs and they get wired something like this:
Hi mmervenne, the FX2N-16MR-ES/UL is 220VAC unit with relay outputs. You simply connect the supply to the leftmost Y0, then connect the rightmost Y0 to your device. This small PLC is a little bit more 'dumb' (as far as the connections are conserned). All bigger FX2N base units use the COMx terminals as a common supply to a group of four outputs (on the right in connection diagram). Hope this helps.
