Guest Tony Jukes Posted November 17, 2005 Report Posted November 17, 2005 Hi guys May be you can help a newbie to wincc I am trying to create a pushbutton with two states State one - Green pushbutton labeled start State two - Red pushbutton labeled stop It should togle a bit in the plc System is TP170B & S7 314 Compact using WinCC 2005 standard. Any help would be most appreciated Regrds Tony Quote
Guest Tony Jukes Posted November 18, 2005 Report Posted November 18, 2005 Well I woke up early this morning and got it sorted Quote
