STORMRIDER Posted November 18, 2005 Report Posted November 18, 2005 I WAS WONDERING ABOUT HOW TO DO A TIMER ON DIR/05, I KNOW THAT YOU TO PUT TMR THEN T1 THEN K 5 OR ANY NUMBER, BUT TO RESET THE NUMBER I HAVE NO CLUE. THE HELPFUL HINTS THAT I GET, SHOW THAT I HAVE TMRA AND WHEN IT COMES UP, IT DOESN'T LOOK LIKE IT SHOULD BE THERE. I JUST WANT TO GET THIS MACHINE GOING. THANK YOU! Quote
GerryM Posted November 18, 2005 Report Posted November 18, 2005 A TMR is a simple timer. Only one input If it is on it times, then when the time expires it turns on. To reset turn off its input. A TMRA is an accumulated time. Has two inputs(enable & reset). When the enable input is on it times, when its off it stops timing, but holds the accumulated time. When it is reenabled it times starting where it left off. Then when it expires the output comes on. To reset enable the reset input. Quote
