wiltsgrain Posted November 22, 2005 Report Posted November 22, 2005 Can anyone help me; I need to optain the following so I can use a A6GPP to alter/save the programs that are run on the two A3ACPU systems we use 1. SW2-GPPA (Floppy disk for starting System for MELKSEC-K) 2. AC30R4 (RS422 cable, 3m); connector between A6GPP and A3ACPU 3. AC30R2 (RS232C cable, 3m) connertor between A6GPP and a printer Thank Nick
Crossbow Posted November 22, 2005 Report Posted November 22, 2005 I would strongly recommend using a laptop and GX-Developer software. Windows-based programming is so much easier than the old programming consoles. Also, you'll want to check out www.meau.com about the discontinuation of the old large-rack A series PLCs. You'll want to talk with someone about an upgrade strategy to get that system moved forward before parts availability becomes an issue. Look for the A Series Transition Center link on the left, or pick Products, PLCs, A-Series.
