When I am trying to install the cx programmer v.5, I am getting the following message: "lincense not installed. using demonstartion mode only" I enter O.K and then the next message apears: "could not initialise cx server. check installation". Can somenoe help me? Thanks, Shlomo
Guest anonymous
Hello Shlomo, Silly question, but is CX-Server actually installed? If 'Yes', try uninstalling CX-Server, including all drivers and the Driver Management Tool, and start again. Regards anonymous
shlomo rubin, Welcome to the forum. There is a CX-Server Removal Tool in the Download Code/Omron/Utilities section of this site. If you need to remove CX-Server, this will be the easiest way to make sure you get it all. Hope this will help.
