I have the above T/C module that reads 6 deg. high across the board versus a Beta Calibrator. Is there a cal procedure for this module? There are no pots that we can see for calibration. thanks, CTG Edited by controltestguy
CTG this is from their website. http://www.telemecanique.com/en/index.htm Do the ARI030 10 and ATI030 00 modules require calibration ? Document Number: RESL2309 Revision: 1.0 -------------------------------------------------------------------------------- Question Do the ARI030 10 and ATI030 00 modules require calibration ? -------------------------------------------------------------------------------- Answer No. Each of these modules employ onboard firmware that will run a continuous self calibration routine. So just a couple of questions: Is this the first time you used a thermocouple module? I see in the setup, you have to tell it where to get the cold junction temperature from - on board or channel one. Which did you select? George
