surfer Posted December 21, 2005 Report Posted December 21, 2005 is there many people out there using entivity or think n do programming Quote
Spanner Posted December 21, 2005 Report Posted December 21, 2005 I used it in College as an example for PC based control. Not the most pleasant tool to work with but I suppose at the moment, I'm using APT to program a Siemens TI555 PLC which isn't much better, Each to his own I suppose! You've a question about it I take it or just a query as to how many people use it? Quote
TimWilborne Posted December 21, 2005 Report Posted December 21, 2005 Used it once and wasn't very impressed. Plus a PC on the plant floor is just a little bit scary to me Quote
surfer Posted December 21, 2005 Author Report Posted December 21, 2005 a factory i do work at uses it it generally works well but relies on microsoft visio underneath for the graphics scada side of things doesnt seem to be a lot of use in oz wondering how much it is used in the states Quote
TimWilborne Posted December 21, 2005 Report Posted December 21, 2005 It was kind of a fad in the late 90s but most companies I know that had it have quit using it Quote
GerryM Posted December 21, 2005 Report Posted December 21, 2005 I used to use it in my testing applications. I had issues when they up/downgraded to V6.0. Ever since then the price tag doubled and it wasn't worth it. I went back to a PLC with a PC for data collection, calculations, etc. for my testing applications. I wouldn't use it on a dedicated 24/7 machine. It was a little clunky overall. I do miss the flowcharts though. I'm not a huge fan of ladder, even though that's all I've ever used. Quote
TimWilborne Posted December 21, 2005 Report Posted December 21, 2005 I have always used ladder too. I'm looking into the Function Block Add on for RsLogix 5000, but I still have sold myself on them being any better. Anybody out there diehard Function Block Programmers? Quote
Ken Moore Posted December 21, 2005 Report Posted December 21, 2005 I've done quite a bit of Foxboro I/A DCS programming, it is 99% function block programming. It's not an easy transition from ladder to FB, the DCS function blocks are very powerful, and can save a lot of time compared to doing the same task in ladder. However, from the demo's I've seen of the logix5000 FB, they have a long way to go, they are very basic compared to the ones I've seen in the DCS system. Quote
TimWilborne Posted December 21, 2005 Report Posted December 21, 2005 I guess my real question is what is the big advantage of function blocks. Where to they really make things easier. I've only used them one time Quote
GerryM Posted January 3, 2006 Report Posted January 3, 2006 I think FB are easier for data type applications, number crunching, PID, etc. Ladder is better for turning solenoids on & off, start/stop P.B.s, etc. Quote
jeffellis1 Posted October 20, 2006 Report Posted October 20, 2006 (edited) Hello, do you know if I can find a demo of the Think N DO software? I really appreciate any help you can give me. Jeff Edited October 20, 2006 by jfls41 Quote
BobLfoot Posted October 21, 2006 Report Posted October 21, 2006 Have used Entivity VLC on a couple of jobs and I can only say one thing. RUN DO NOT WALK AWAY. What takes 1 day in PLC takes 1 week in VLC to debug. Quote
TConnolly Posted October 21, 2006 Report Posted October 21, 2006 I used "Think & Do" ONE time. If I have anything to say about it that statement will never change. Quote
Peter Nachtwey Posted October 21, 2006 Report Posted October 21, 2006 I did a project using think n do. It worked well. The project involved controlling over 100 axes and some temperature PIDs. The performance was good. I wrote one chart that was activated once for every axis. I think you have to get the hang of programming using flow charts before starting a project. If you try using Think n do like a PLC you will be fighting it every inch of the way. What I didn't like was connecting the blocks and all the time it took to rearrange the blocks. There were about a half dozen other things that I found aggravating. Quote
BobLfoot Posted November 2, 2006 Report Posted November 2, 2006 Peter ism inserting a decision block and changing the order of blocks as time consuming and frustrating in Thinkand Do as I found it it VLC. Simple tweaks for a PLC became a major rewrite for VLC. Quote
Peter Nachtwey Posted November 2, 2006 Report Posted November 2, 2006 One could insert rows or columns but all the broken connections had to be rewired. It wasn't too bad. Honestly, I would have prefered to enter the data in text using a text editor and then let the Think N DO display the blocks after compiling. Often times our electric cad designs just put labels on the wires. All the wires with the same name are considered the same even though the wires don't look connected. I wish they had do that on the Thknk&Do. Quote
