Guest milan Posted December 28, 2005 Report Posted December 28, 2005 Hi all, I'm using Omron CS1G PLC, ETN11 ethernet card, switch and F650 Realy from GE. Software: CX-programmer, EnerVista for F650 demo version, and Wonderware InTouch. I like to establish communication to F650 via CS1G from Wonderware. I configured the IP addresses and i have ethernet connection. F650 use Enervista Integrator OPC/DDE Communication server.(don't have) Omron use Omron OPC or OmronNETH. (demo version) I like to send/recv data and configure relay parameters from F650 in Wonderware . CS1G will work as master and F650 will work as slave. I will appreciate any given suggestions. Thank you Quote
