piscis Posted December 31, 2005 Report Posted December 31, 2005 I need to connect 4 PLC’s models 90-30 with the following CPU: Rack 1 CPU 332 Rack 2 CPU 340 Rack 3 CPU 331 Rack 4 CPU 363 The project requires a PC HMI reading all the variable registers inside the PLC’s. I have at least one empty slot in each PLC. Could someone please recommend a communication module to place on each of the PLC? I need you help with the following issues: Which communication part number Modules and Cables to buy for each PLC? Which PLC do you recommend as the Master? Thanks for all your answers. Andy
Steve Bailey Posted December 31, 2005 Report Posted December 31, 2005 See my response here: http://www.plctalk.net/qanda/showthread.php?t=19658
