jcbarnar Posted January 3, 2006 Report Posted January 3, 2006 (edited) Hi, I am new! I need to communicate with an S7-300 series PLC that has a CP343-1 Lean and I want to use my laptop which has a typical NIC card. I will be using Wonderware InControl as an OPC client. I know that I can use Wonderware's SI Direct DA Server to do this, but I would like to try some different solutions. Kepwares KEPServer EX looks good as well, but my real question (assuming I'm correct so far) is whether I can do this with SIMATIC Softnet S7? Thanks so much! /jeff Edited January 3, 2006 by jcbarnar Quote
JesperMP Posted January 4, 2006 Report Posted January 4, 2006 Yes. Have done so and it is easy. All you need is a NIC with TCP/IP enabled. Quote
