Try the S7 Canopener by RUNMODE. There are others as well. Or Send me the project and I will remove it for you. Edited by Moggie
Here read this message from randomFire another member in MrPLC. If you find his message, you ll find an attached file. it works, i tried. yes of course it cause a lot fo work but as i said "works". of course try this solution if you dont have S7 Canopener """"""" easier way is to use a dbf editor. SHUT DOWN S7, then browse to your project file e.g. c:\my documents\some s7 project\ombstx\offline\00000001 and within this folder is a file called 'subblk.dbf'. Copy this file onto root i.e c:\. Then place the dbf editor on root c:\ and open a dos prompt. Then type c:\dbf_edit subblk.dbf and this opens the file for editing. Then using the right cursor, scroll along until you see the column 'password'. Then look for instances of the number '3' and replace it using the enter key for a number '0'. Press esc to exit the program and then copy c:\subblk.dbf back to the original place you copied it from. start S7 and open the project, the KNOW_HOW is no more.""""
