I assume you have an OP25 that is "running" and you want to change this to an OP27? Have you a copy of the OP25 program? You will also need a copy of Protool. This is the configuration software for the OP's. If you have a copy of the OP25 program it should be easy to set it up for an OP27 using the Protool software program. You will also need the correct cable to connect your computer to the Op to download the configuration. Hope this helps? Steve
Hi, this is from the help file of Protool................. Projects cannot be uploaded in the case of the TP 170A. As a result of a download operation, the executable project is normally downloaded to the operating unit. If you want to use the original project data for developing the project further or for error analysis, they must remain on the configuration device. On Windows CE devices (only with external storage medium), you can store not only the compiled project but also the source code of the project so that subsequent retrieval (uploading) of the project from the operating unit is possible. In this way you can later perform analyses and changes to an existing project even if the original programming device cannot be reached or the source file (*.pdb) for the project is no longer available on the configuration computer. Sufficient storage space must be available on the operating unit. The storage location for the source file must have been set on the operating unit. Different storage locations can be set for the project file and source file: internal flash memory or PC card (refer to equipment manual). The project file must be downloaded with the source file. What happens during download and upload operations? When the source file is transferred during a Download operation, the project is compressed from the source format (*.pdb) and transferred as a *.pdz file to the external storage medium of the operating unit or directly to the PC. Following uploading, the file is decompressed in ProTool. You have to give the new project a name on the configuration device. Note The uploaded and decompressed project file (*.pdb) can only be opened in a version ProTool whose version number is higher than or equal to the version number of the program with which the project was created.
Iam sorry you need to have the original Protool project for your Op25 to convert it to OP27. There is a program called Prosave that can recover lost projects but it only works with the new panels like OP7,OP27 and Tp170.
