Rebooting computer with S7-300
Does anyone know how to reboot the PC using S7-300 CPU. My HMI computer always hang... I would like to use the WOL function in the computer to reboot it... Have anyone tried this before? It will involve sending packet of data through the ethernet..
Heya West_ I would more ask the question, "Why is My HMI Computer Hanging". We had a bit of a problem here where 2 applications on the HMI Computer were in conflict over ethernet port 1505 causing the procesor to work 100% for a while giving the illusion of Hanging up. Another Hangup we'd seen here was a bit of a bugger to find. We use intouch 7.1 and 8 here and programmed into intouch is an option to print the page using the Key script for "Ctrl+F12". The problem was caused by Operators Pressing Ctrl+Pause/Break instead which if selected (Often by default) in the windowmaker - Windowviewer configuration settings stops running all scripts. (SEE ATTACHMENT) What HMI Software are you using?
