Omron Sensor Controller S3D8-CKF-US
The controller mentioned in the subject line is no longer available. What can I use as a substitute? The Omron unit was very easy to adjust for my customers, not requiring any formal training. It merely sensed input, and provided outputs, and operated on low voltages so it was safe. Any help would be most appreciated. Thanx
Guest controlsMan
Omron has a new sensor controller which takes the place of the S3D8 controller. The product family is the S3D2 sensor controller and you can find the spec's on this controller on the omron website.
Guest froggies
Hi I am looking for the leads use for uploading the plc program in a laptop. If I can get the part number. The connection is a flat ten pin connector. Regards
