can anybody tell me , As we have to use TO/FROM instructions to data transfer between PLC & EJ71E71, is it possible to access PLC DATA using this ETHERNET. If yes please tell me the settings in "TRANSFER SETUP".
yes, you can use TO/FROM to setup ethernet card and initiate data transfer between two plcs. For example you can READ (or write, or both...) block of data (D or M device or whatever) from another plc on a network. this will likely be quite challenging if you do it on your own, specially if you have no experience with ethernet and programming of mitsubishi comm cards. read this: http://forums.mrplc.com/index.php?showtopic=6090 note that third reply has sample code that sends unsolicited message (block of data registers) to another plc. (well it was PC with driver simulating another PLC).
