Yes. If, for example you are using Siemens operator panels for your HMI, then the application can be ported from an panel to a PC. The operator panel application is made with Protool or Win CC Flexible Standard or better. To make the application on a PC platform Protool Pro or Win CC Flexible Advanced must be used. In addition a runtime license must be purchased for the target PC. Both the engineering software and the runtime licenses cost money ! There are many other possible solutions, including other vendors than Siemens.
