I am using PL7 Pro V4.5 Is there a quick way to select variables or addresses when they are entered above the contacts in ladder? At the moment I need to have a list handy of all variables and i/o addresses to add them to contacts. I was hoping there would be a shortcut allowing selection of used addresses instead of having to type them in, similar to AB, Omron, etc. Thanks.
I have contacted Schneider Electric and it seems that in PL7-Pro you can only enter address/symbols to contacts by typing them completely. There is no shortcut or pop-up table to select symbols from as in AB, Omron, etc. Too bad, this makes the programming very labour intensive.
