Chris Elston Posted July 3, 2003 Report Posted July 3, 2003 prasadchaparala (prasad.chaparala@pepsidrc.ae) on Thursday, July 3, 2003 at 06:04:36 --------------------------------------------------------------------------- comments: how to communicate with mitsubishi melsec FX-48 MT PLC by using GX-Developer-FX series software, intelligent adapter FX-232ADP and SC-09 RS232/RS422 converter cable. --------------------------------------------------------------------------- Quote
Sergei Troizky Posted July 6, 2003 Report Posted July 6, 2003 The FX232-ADP has nothing with PLC communication for programming/monitoring purposes. This is an extension module used for data exchange with external serial devices under the ladder program control. All you need is the SC-09 with the Mini-DIN adapter removed from the 25 pin connector. Quote
