hattab fethi Posted March 7, 2006 Report Posted March 7, 2006 I have documents which explains the protocol ppi (explains the formats of frame accepted by the CPU of the S7-200 automat). I wrote a code which ensures the communication between PC and s7-200. I tested but it does not function I have make several checking: - I have an achievable file which ensures the communication between PC s7-200. I used a serial monitor to know the frame exchanged between PC and automat I noted that they similar to those are used in my code I have doubts about times (use of structure COMMTIMEOUTS) typedef struct _COMMTIMEOUTS { // ctmo DWORD ReadIntervalTimeout; DWORD ReadTotalTimeoutMultiplier; DWORD ReadTotalTimeoutConstant; DWORD WriteTotalTimeoutMultiplier; DWORD WriteTotalTimeoutConstant; } COMMTIMEOUTS,*LPCOMMTIMEOUTS; language used is C++ if you have in more one idea on others problémes which can met us. To indicate us Doc1.doc Please help me Quote
PLCMania Posted April 9, 2006 Report Posted April 9, 2006 Hi, Is it possible for you to send the rest of document(doc1.doc) too? Quote
