valerio81 Posted March 15, 2006 Report Posted March 15, 2006 hi. i've got a problem. i'm using cx-one v1.11 i have one project on cx-programmer with some function blocks. when i start the simulator (v1.6) and i click on memory card in cx-programmer appear a file without doing nothing... this file is "srcprgrm.fbl" someone knows why there's this file?? my problem is that when i want to simulate the doing of a memory card i have this files: - AUTOEXEC.OBJ - ATEXECDM.IOM - AUTOEXEC.STD - SRCPRGRM.FBL and then when i download this files on real plc doesen't work.. someone know how can i have only the first 3 files and not the 4th? thank you. valerio Quote
@q_spasi Posted March 15, 2006 Report Posted March 15, 2006 hai hai... meybe, something u'hv forgotten: emmm: dip switch setting no 2 or 7 refer to w339 sec6-1 sorry i'hvn't met *.fbl yet Quote
valerio81 Posted March 15, 2006 Author Report Posted March 15, 2006 it's not a dip-switch problem.. this problem happens only when i use function blocks.. and the file .fbl appear only with cx-simulator... if i do memory card with real plc i have only 3 files but if i do memory card with cx-simulator i have 4 files ( as above ) . it seems that in second case AUTOEXEC.OBJ is splitted in 2 files AUTOEXEC.OBJ & SRCPRGRM.FBL there's a reason?? thanx again Valerio Quote
