I was in a situation to recommend an OPC server to an end user for communications with an ethernet GE 90-30 PLC and FactorySQL, an OPC client. We ended up using Kepware Ex, and it worked fine. What other OPC servers have you used/would you recommend? Please post your experience and advantages/disadvantages of each. Thanks. ---- Nathan Boeger Integrator, Microsoft Certified Systems Engineer Inductive Automation "Specializing in SQL and web based HMI systems"
