S7-200(cpu 224) Connect To Wincc 5.0 Sp2
Guest mien chi
Can i connect s7-200 to Wincc ? I have Pc-access v1.0 sp1, Please help me!! Thanks
PC Access is your OPC Server. The best solution is to get a CP243-1 ethernet module to talk to your WinCC SCADA package. You can do it via serial using either of the PPI adapters but is much slower at 187.5kbaud. WinCC will be obviously setup as your OPC Client and PC Access will be the OPC server. Keep in mind that PC Access only allows for 8 connections so if you need to connect to more than 8 PLCs you must purchase SimaticNet to unlock the other channels. Good luck! Khek
