Has anybody used a Q series Serial Communication card QJ71C24N to talk to a third party device before. I'm trying to get some values (i.e. oil temp, control mode, etc.) from a York compressor via a COMSAB II interface. I've read the manuals which are a little confusing. The message format required is as follows; 'STX-CODE-INDEX-POINT-DATA FIELD-ETX' where, STX = Starts Telegram CODE = Indicates Read or Write Telegram INDEX = Compressor No. To Talk to POINT = Address of Variable Required DATA FIELD = Variable Value ETX = Ens Telegram Any pointers on how to frame this message for sending and receiving information or some sample code to get me started would be appreciated.
I would specify the header and terminator that you have, and just fill in the junk in between. The Mits plc cards have these type of setting on them. I have not used the Q 232 interface module, only the FX2N. I would assume that you would need to set the card to only do freeport/ no protocol mode. Check that you are sending the correct info the the York compressor with another port connected to the PLC card and a Hyperterminal or similar session. Sorry, do direct answers from me. Maybe the pointers that helped me will assist you. Regards, waynes
