Guest notsosure Posted July 24, 2003 Report Posted July 24, 2003 I heard there is a Mitsubishi PLC supporting 120 VAC digital I/O. IS that true? Quote
navillusi Posted July 24, 2003 Report Posted July 24, 2003 FX Series PLC's with AC inputs: FX2N-16MR-UA1/UL 8 inputs (110V AC), 8 relay outputs, 100-240V AC supply FX2N-32MR-UA1/UL 16 inputs (110V AC), 16 relay outputs, 100-240V AC supply FX2N-48MR-UA1/UL 24 inputs (110V AC), 24 relay outputs, 100-240V AC supply FX2N-64MR-UA1/UL 32 inputs (110V AC), 32 relay outputs, 100-240V AC supply Qn Series PLC AC Input Module: QX10 16 point, 100/120V AC (7mA), 16 points/common QX28 8 point, 240V AC, 8 points/common Qn Series PLC AC Relay Output Module: QY10 16 point relay 240V AC/24V DC, 2A contact, 16 points/common QY18A 8 point relay 240V AC/24V DC, 2A contact, all points independent QY22 16 point triac, 240V AC 0.6A/point, 4.8A/common, 16 points/common A Series PLC AC Input Modules: A1SX10EU 16 point 110-120V AC (6mA), 16 points/common A1SX20EU 16 point 200-240V AC (9mA), 16 points/common A Series PLC AC Relay outpur Modules A1SY10EU 16 point relay, 2A contact, 8 points/common A1SY14EU 12 point relay, 2A contact, 4 points/common A1SY18AEU 8 point relay, 2A contact, all points independent Quote
