Can you see what is wrong with this product? The sticker says it's a BJ1 part number which is a base for a single valve. When in fact, it's a double valve board installed inside. This really isn't a problem unless your using this base with a network like Profibus or DeviceNet. A mistake like this will mess up your bits you have allocated to each manifold. Bottom line, the sticker on this base is not what the part actually is. This part is actually a BJ2 part number. We had two bases that came from MAC this way. Mis-labeled parts.
