WKla Posted April 2, 2006 Report Posted April 2, 2006 I have two Westermo GD-01 modems. I’ve connected each to separate PC’s. The communication settings are the same (ICF=3,4 – 8bits,1stop,no parity). The problem is that when I make a call to the other modem and it answers the call, no data can be transmited (if I write something to one terminal it doesn’t appear to the other end). Suggestions or anything… Thank you. Quote
Supporter Posted April 2, 2006 Report Posted April 2, 2006 Hi, Are you sure that you are using the same baudrate for both the modems? (AT+IPR = 9600)? If you are using Hyperterminal you could try to use Flowcontrol = none. Regards, Supporter Quote
