MEK Posted May 2, 2006 Report Posted May 2, 2006 do you have any idea about the connection cable of 90-30 series to pc. Quote
Camel Posted May 2, 2006 Report Posted May 2, 2006 It's just a null modem cable. You do have to have an SNP adapter. Maybe Steve can help you out with a part number. (I can't find my adapter) Quote
Smoke Posted May 2, 2006 Report Posted May 2, 2006 Here is a part number for a cable with the SNP adaptor molded to the cable. If you need, I can get you the part number for the SNP adaptor separate. AS69232SNP Quote
RussB Posted May 5, 2006 Report Posted May 5, 2006 Or: See attachment but it is not supported by GE Fanuc. Quote
naing Posted May 5, 2006 Report Posted May 5, 2006 Hi MEK, The attachment will help you. If it isn't OK yet, I can support you with schematic diagram of my own adapter (DIY version) and connector pin-out. SNPSerial.pdf Quote
MEK Posted May 10, 2006 Author Report Posted May 10, 2006 thanks naing I will inform you about it works or not as soon as possible Quote
