Hi guys, I'm new at this. I have an FXON-24MR-ES with an EEPROM FX-EEPROM-4C. The GX Developer will not let me Convert the rung additions that I made because of the EEPROM. I've switched the EEPROM to OFF but it still wouldn't Convert. The Write to PLC (Flash ROM) is greyed out. Any suggestions?
You cannot use the 'Write to PLC (Flash ROM)' for a FX Type PLC. Just write to the EEPROM like the normal memory. The memory card overrules the internal memory. Before writing to the EEPROM switch it to off. For more detailed information over flash rom memory read the manual for GX-Developer (GX Developer v8 Operating Manual [082005].pdf) section 16.5.
