JDull Posted May 12, 2006 Report Posted May 12, 2006 I have read several post that imply the Series One controller and the Automation Direct (Koyo) controllers can be interchanged. Are there any cross reference sheets out there that show this compatibility? Thanks in advance for any help. Jeff Quote
Steve Bailey Posted May 12, 2006 Report Posted May 12, 2006 The GE Fanuc Series One is the same thing as the Automation Direct DL305. DirectSoft software can be used to program some, but not all of the GE Fanuc CPU models. The GE Fanuc unit must be what was called a Series One Plus. That means that the CPU model must be IC610CPU105 or IC610CPU106. Quote
