Guest Hickman Posted August 17, 2003 Report Posted August 17, 2003 I need to control 12, 3-ph motor-starters, allowing NONE of them to 'start' simultaneously. It's a load-balancing problem, but I only need to balance the start-up period. Any or all 12 units may 'run' simultaneously. I need to limit them to 1 unit starting at a time. I currently have a program written in Concept that 'gets the job done', but it's not very effecient. It checks to see if Input_1 is requesting service. One way or another, it waits 30 seconds before scanning to Input_2, etc. I need a design that scans Input_1 thru Input_12. Once it finds an input that is requesting service, it allows that unit to start, then waits 30 seconds before proceeding with the scan. I hope that makes sense. It's a lot easier for me to understand what I need than it is to try to convey it to others. Thanks in advance for the help!
Guest Kempfj Posted August 18, 2003 Report Posted August 18, 2003 Give us the plc info and the I/O configuration. Can the motors be started in 1 thru 12 sequence? What about shutdown, interlocks and manual operation? I'd use proworkx NxT to do it. I think it'll convert it to concept.
Guest Hickman Posted August 18, 2003 Report Posted August 18, 2003 (edited) I'm using a Momentum: 24 VDC power, inputs and outputs. There are 16 ins and 16 outs. [Can the motors be started in 1 thru 12 sequence?] They should be 'checked' for service in order. These units are currently started by pressure or temperature or humidity or .... whatever. That will remain the case. I will place relays in-line to allow control by the PLC. Again, I'm only controlling the start-up of each unit. [What about shutdown, interlocks and manual operation?] This part of the design is irrelevant. My only requirements are as stated in the original question. [i'd use proworkx NxT to do it. I think it'll convert it to concept.] I don't have ProWorkx Nxt. I have Concept. The logic is the same no matter what you write it in. Edited August 18, 2003 by Hickman
