naing Posted May 20, 2006 Report Posted May 20, 2006 Hi GURUs! I have a plan to install a new system at the old plant using A series PLC from Mitsi . The original plant has many of level transmitter for level-viewing purpose. The transmitters use 20mA standard. Now, I intend to use AD converter modules (A1S64AD) with A2SHCPU. ****Can I configure the modules in my ladder program? If it is possible, please give me an example.**** Thanks all. Quote
waynes Posted May 20, 2006 Report Posted May 20, 2006 Hi naing, I have added a sample program for the A1S68AD card for your perusal. Link: http://forums.mrplc.com/index.php?autocom=downloads&showfile=567 Quote
beljic Posted May 20, 2006 Report Posted May 20, 2006 Here is my implementation of A1S68AD: A1S68AD Function block ANALOG_PRG.txt Program with instance of A1S68AD A1S68AD_IMP.txt Quote
