Smoke Posted May 25, 2006 Report Posted May 25, 2006 Do any of you use Microscan Mini 2D barcode readers. I do not use the microsan power supply on the machine just a 5vdc power supply. I have to user there power supply though when I program the scanner. Has anyone built a programing cable using power from the com port? If so can you show me how you built it? Thanks Quote
