I thought it is me, but looks like I see other posts like this with empry spaces about inch high between lines. Every time I post, I have to go back and edit post to remove double and tripple <Enter> lines to make post readable. Same with PMs: they look like "long but empty story book". This started day or two ago - Chako please take a look. Here is an example: http://forums.mrplc.com/index.php?s=&showt...indpost&p=34543 Edit: and look at this post same thing! Edited by Contr_Conn
Ok guys... I think I figured it out. IE6's editor gives me a double enter if I hit <Enter> and a single enter if I hit <Ctrl-Enter>. (It's the same thing my webmail does.) Firefox's editor gives me a single enter every time. For now, I think I'm switching to Firefox.
Having the same thing here with IE6. Didn't really notice it was consistent but indeed. <Ctrl-Enter> does not work for me though. Seems there is a space line by default. But as far as I remember it was also there before in v2.1.4 ?!?' I don't want to go Firefox though... the gf doesn't like it and I have to admit I'm not to crazy about it either...
Something is not right <Enter> These extral lines look very strange <Enter> Short PMs taking full screen. Firefox test <Enter> Previous post was in IE<Enter> See the difference? Edit in Firefox: I actually added new post and 3 lines were added to the previous post ... This can't be right... Edited by Contr_Conn
Using standard editor <ENTER> Seems to be ok.... <ENTER> So it's related to the Rich Text editor. One step closer...
Standard text editor single enter Standard text editor double enter What is the different between the standard text editor and the rich text editor. I notice I have to right click the text area for IESpelling. What else is different?
Reply typed in word. Copy and paste in reply window with default settings Using FireFox Font Normal Arial Narrow size 10 I have always had problems with the double space
I can confirm the problem is with IE only and rich text editor. It's always been a problem. I changed the source code to the old 2.1.4 version and did the same thing. I have posted a bug tracker at Invision, I am awaiting a response. For a work around, please use either FireFox browser and Rich Text Editor, or change your editor to Standard mode if using IE. This should fix the problem for now. I'll post back if I hear anything.
Standard editor is fine for me, as long as I can copy and paste. I am not complaining, just see this as a bug that should be addressed I guess. I never saw this before until the upgrade, I went back to my old posts and PMs and it did not exist. I was not sure if this happened because of upgrade or hacker activity, that can be much serious issue === This post typed in Standard editor IE6 with single return.
I didn't have the double line problem till the upgrade. I'm fine with the standard editor. The only difference I can tell is spell check icon is not there. Right click and problem solved
The only other difference I can find between the standard and rich editor is the formating such as bold, italics, underline, hyperlinks, etc are not hidden. A little confusing but don't see why IE users can't use the standard editor for now
