darko79 Posted May 31, 2006 Report Posted May 31, 2006 Hi, I use CP340 module with CPU312C. How to realize signal REQ, when using P_SEND command to send data from CP340 module. I program in S7 SCL v5.3.Can you write me short sequence.I use P_SEND in FB.Thanks Quote
