I thought I would post a little data. I have noticed a lot of programmers use a string of Move commands when storing integers to get averages etc. Here is a shortcut with an Array move I hope some might like it.
Thanks, you are right. Once you master the Array function blocks you can make your PLC do anything but sing. This thing can be used to handle bits, bytes, words or double integers. Along with the Array look-up function blocks it is very flexable.
