cauchy Posted June 22, 2006 Report Posted June 22, 2006 Hi, I will control a D.C. motor with a FX2 PLC.Im using GX Developer. This motor start to run with acceleration. (Firstly slow and it will speed up with a ramp in 2-3 seconds). And motor will be slow down end of this motion. (This motion's Velocity-Time curve will be similar with y=X^2 function.) I know smoothly data operation in GX. How can I do with GX Developer, Which function can I use? Thanks for helps... Quote
