shehoxs Posted June 29, 2006 Report Posted June 29, 2006 Dear sir, How to cange leader Program from EEprom FX 2864 to Ram on CPUFX2c Bicause if condition Run I am Remove that EEprom,PLC run that leader well withaut EEprom, but affter PLC stop(OFF) that Leader cant hold on Ram PLC that battery good, so for Run PLC I must Place the EEprom Again. If I look from the Leaader step size 2741 and the Ram Capasity thePLC 2k so if I download the Leaader Massage from PLC memory small than step size, And i change memory ON parameter with 4k than I down load again apear massage Memory Exceed. What the solision for this?, because i wont PLC run with ram on PLC and EEprom for master for this PLC or the other machine Best regards Quote
