Buzz Posted June 30, 2006 Report Posted June 30, 2006 Does anyone have the pin-out of the programming interface plug on the GE Fanuc series one CPU module? Although I have the Programmable Controller, I want to design some other interfaces. Thanks in advance.....Buzz Quote
Steve Bailey Posted June 30, 2006 Report Posted June 30, 2006 I'm pretty sure that the port on the CPU where the handheld programmer and other accessories plug in is proprietary. Normally, for serial communications you install a data communications unit. Pinouts are available for that. The Series One is the same thing as the Automation Direct DL305 line. Data communications units are still available from AD. You can also download user's manuals from their website: http://www.automationdirect.com The Series One manual is also available in the downloads are of this site. http://forums.mrplc.com/index.php?dlcategory=15 Quote
