kmd Posted July 6, 2006 Report Posted July 6, 2006 Hello Any body can help? I don,t connection ProTool with OP17, have eroor E2044. I have this diagram connectin cables: op17 pc 15-pin 9-pin 10------------------------------7 3-------------------------------2 4-------------------------------3 5-------------------------------8 15------------------------------5 Any body know correct this diagram or not? Quote
kmd Posted July 6, 2006 Author Report Posted July 6, 2006 Hello Or i need use this diagram for connection? op17 pc 15-pin 9-pin 3----------------------------------3 4----------------------------------2 12--------------------------------5 -7 I -8 -1 I -6 I -4 This cables 6XV1440-2K... What cables correct for connection op17 with P?? Quote
gruntstripe Posted July 6, 2006 Report Posted July 6, 2006 (edited) Hi Kmd, You have the correct cable 6XV1440-2KH32. Don't know what your error message is - cant see that one in the manual (available from the downloads section of this forum). Can you get into download mode ie. ESC + UP CURSOR when turning panel on or alternatively via System Settings/Opmode/Download ? Edited July 6, 2006 by gruntstripe Quote
kmd Posted July 7, 2006 Author Report Posted July 7, 2006 Hello Thank for info about cables. I have 2 panel op17, old panel and new panel, i want upload progran from this panel and download in new panel. In old op17 destroy many button (ESC destroy too). I can not press "ESC" + "up" bighouse "esc" button destroy, can not make "Transfer mode". Connection with new panel correct. What can i do in this situation? Quote
PLCMania Posted July 8, 2006 Report Posted July 8, 2006 Hi, If you want to transfer the program from one OP17 to another one. it is better to use the Prosave. Good Luck Quote
scatter17 Posted August 15, 2006 Report Posted August 15, 2006 in creating the program,there are standard menu for transfer mode,,if the programmer configured it in the screen,,a big problem if not included Quote
