I want to program FX1N PLC with my laptop at field, but my laptop is not having COM port, my computer vendor suggest me to use USB to COM port converter. I am not sure that this converter will program my PLC or not.
I use a USB to serial convertor and have not had any problems with FX plcs I have also seen the PCMI card adaptors which were troublesome and looked very fragile for on site progamming
Keyspan adapter works awesome! I've been using one for a while now and haven't had a single problem with it, or connecting to a plc.
Was wondering. I just hooked up a Keyspan USA-19 (got it some time in the late 90s early 2000) downloaded the drivers, installed drivers, and still could not connect to a FX2n PLC using SC-09 cable running GPP v5. Any ideas? Thanks in advance, Tolnak
That might be your software. I had a few problems with just a serial port with gpp-win. Mainly connecting to some 'A series' through a 'E series' HMI. I lost connection frequently - it used to scare the hell out of me when altering code online With GX dev I have never had the same problem
Hmm, gonna take this thred a bit off topic. I have a copy of GX dev 8 on another machine but, I don't have the install disk. Is there a way to move a copy of GX dev from one machine to another? Tolnak
There is another option for the FX1S/1N/2N/2NC/3U. It's the FX-USB-AW, which is a cable that goes into the 8-pin round plug on the PLC and is USB on the PC end. As for the moving a GX-Dev from one PC to another, yes you can move your license from one to the other. There is a process for this. Contact MEAU support at tsg@meau.com and they can email you the process. But if you don't have the install disk, you can't move it. You'll need to reinstall it on the new PC and then move the license. So until you have the CD, you're SOL...
I figured as much with moving the license. Thanks for the help anyway. I will say that I downloaded the GX dev 8 demo, from this site, and it is working fine with a Keyspan USA-19!! So, I'll have to get a new copy of GX dev 8 hehe. Thanks for all the info and help, Tolnak
I have to carry 3 USB to serial adaptors around with me ! One works with Mitsi but not with Klockner etc. They're certainly not a standard item.
for all the communication problems i suggest you all to go with the serial port pc only which will never give you problem. or else use PCMCI serial adaptor which also works better. thanks
Sorry, but I'm not completely agree with vaibhav about PCMCI adaptors. Couple months ago I tried to use such adaptor and with GX IEC Developer it worked fine, but it didn't work with GT Designer, so I was unable to download project to the GOT panel.
