What is the cost difference between buying 8x 0..10 -> 4..20mA converters and 1x A1S68DAI?
Are you looking for a readymade unit to convert volts to amps or are you planning to make the circuit/unit yourself?
dont know how cheap you want but i like to use Brodersen process signal convertors have a look at RS part number 324-0740 its £86 you may be able to make something yourself i dont know how but by the time youve finished messing about with prototypes its costs more money than buying a ready made item which has been tested and should give years of trouble free service.
Thanks, All. An A1S68DAI is about £650 list price, and I would need to convert all of them. Based on around £85 per channel, then there's not a lot of price difference, so the A1S68DAI is the obvious solution. I just wondered if anyone knew of an 8 channel version for around a couple of hundred pounds or so, but it seems like they don't exist. Thanks again.
