siame Posted August 11, 2006 Report Posted August 11, 2006 need a example of hayes commands and configuration of a communication between 2 plc twido via modem (wavecom gsm dual band WMOD2B). thank`s Quote
lazy Posted August 12, 2006 Report Posted August 12, 2006 The wavecom modem is the same as the westermo modem. The command line sheet can be found at the following address: http://www.westermo.com/dman/Document.phx/...amp;action=save This does for the PSTN, Long/Short haul modems and GSM Quote
