Hello, is it possible to copy structure tag to another, but without using scripts. The best way it'd be to: Object properties->Events->Mouse action->Direct connection and is it possible as a source tag to put: valve_1.* and as a destination faceplate.*. (source:valve.tag1---destination:faceplate.tag1 works fine, but I need to copy them all) I need that because I want to create universal valve with faceplate so when I copy that valve all I'd have to change is to structure name like: valve_1.tag1 to valve_2.tag1. When I call faceplate is shoudl call it: if it is valve_1 then copy structure tag valve_1.* to faceplate.* and display faceplate and valve_2: valve_2 to faceplate, ..... It saves tags and time to create faceplate for each valve(valves are the same). Ps: I can't use scripts in my objects, because when I use Linking->Tag connections->replace name it won't change names in scripts. Thank you for any help.
Edited by boger
