arsenen8 Posted August 19, 2006 Report Posted August 19, 2006 How can i poll the modbus address from the siemens S7-200 CPU224? The software i using is Step7 MicroWin V4.0. Is it any function need to be added? Please help. Thankyou. Quote
khekd Posted January 10, 2007 Report Posted January 10, 2007 Here is the code example for the modbus master. you will have to read the rung comments very carefully because those are the only help files. And you have to view them in STL to get all the detailed comments. It is doable because I have several people using this to talk to VFDs and weigh scales. Good luck! Modbus_master.zip Quote
