Vomitz Posted August 19, 2006 Report Posted August 19, 2006 Hi Guys, cannot seem to get the spare part for AD76S anywhere so wondering is there any other PLC model that can replace the existing AD76S? Regards Quote
panic mode Posted August 21, 2006 Report Posted August 21, 2006 one was on eBay: http://cgi.ebay.com/MITSUBISHI-AD76S-LNC-A...4QQcmdZViewItem --- edit --- can you provide more details? seam to be 2-axis motion controller. what are the drives? what is the processor? are you using both channels? Quote
Vomitz Posted August 22, 2006 Author Report Posted August 22, 2006 not sure how many channels i'm using. it's used on an old plastic injection machine. Quote
panic mode Posted August 22, 2006 Report Posted August 22, 2006 ?? do you have drawings of the machine? do you have manual for the card? Quote
FNMdeJong Posted August 22, 2006 Report Posted August 22, 2006 Try to google and you will find more modules. Personally i don't know the module, because it was not released in europe. But are you sure it is a motion controller. Don't you mean a positioning module??? Quote
panic mode Posted August 24, 2006 Report Posted August 24, 2006 i'm not sure of anything, couldn't find a trace of any manual for it. to replace it with something else, one has to know at least what cpu, what drives, number of drives are controlled by it. having original prints will be helpful (wire numbers..). Quote
