davidtorati Posted August 21, 2006 Report Posted August 21, 2006 Hello I want to work with an old PLC of Landis & Gyre Called PRV 1.64 . how can I get the programming software ( dos version ). Thanks Quote
TimWilborne Posted August 21, 2006 Report Posted August 21, 2006 Is this a Siemens Plc? You put it in the Siemens section. I will move it back if it is a Siemens Plc Quote
TimWilborne Posted August 21, 2006 Report Posted August 21, 2006 Ok after a quick search I found THIS which leads me to believe that it is a Siemens Plc Quote
