J@ck Posted August 31, 2006 Report Posted August 31, 2006 HI, I have a small problem with sfc 59 in 7 315 2dp I would like to read from AS-i digital input values wchich comes from Analog-Digital Converter. (Temperature) The most important thing are LADDR & RECNUM. LADDR is a logical number of as-i gateway or maybe is address of digital input ?? Regards J@ck
J@ck Posted September 6, 2006 Author Report Posted September 6, 2006 Hi, I found the sollution. Maybe it will be useful for someone LADDR is a adres of a gateway that you are using to control AS-i. RECNUM number of records I insert 8C (140 bytes) after this everything was quite ok Regards J@ck
