ChanThien Posted September 4, 2006 Report Posted September 4, 2006 (edited) I tried to connect many times and checked cable graph, parameter .However, PLC can't connect with PC. If anyone know how to do it , please tell me.Thank you! Edited September 4, 2006 by ChanThien
funfrok Posted September 4, 2006 Report Posted September 4, 2006 Maybe you are not choosing C24 connection, in the transfer setup menu.Please look at the attachments. C24 modules have the same pin layout as pc, but with female connector. You can use null modem cable with, male-female connectors and some extra connections for flow layout. I think you know this but i wanted to write, just in case.
ChanThien Posted September 4, 2006 Author Report Posted September 4, 2006 Thank you , funfrok! I will try again.I hope i will be successed.
